Group: DynoMotion Message: 12227 From: Hardy Family Date: 9/8/2015
Subject: Suggestion for KMotionDLL
We made a modification to the DLL in CompileAndLoadCoff() where it accepts a missing source file provided there is a .out file for the target thread.  Not sure if I missed somewhere else that it already allows this, but it works for us anyway.
A few reasons it is useful:
- if CL6X must be used to compile
- if OEMs (like us) want to distribute proprietary stuff object only.
- slight speed improvement for user buttons.
Can't think of much down-side to this, so I submit it as a change request that some others might find useful.
On a related note, we have good results running the KMotionServer on a Raspberry Pi and talking to it over TCP/IP.  Currently, this is only an option for Linux PCs, but I'm thinking of adding a new constructor to the DLL to use winsock, and doing the winsock programming so that even Windows applications can talk to their kflop+R.Pi over Ethernet.  If and when I get that done, would you want to add it as an official feature?  Free open source, of course.
SJH
Group: DynoMotion Message: 12229 From: Tom Kerekes Date: 9/8/2015
Subject: Re: Suggestion for KMotionDLL
Hi SJH,
You should be already able to just call LoadCoff if you have the file already Compiled.
The TCP/IP interface would be great.  We would like to add it as an included feature.
Group: DynoMotion Message: 12230 From: Hardy Family Date: 9/8/2015
On Tue, Sep 8, 2015 at 3:55 PM, Tom Kerekes tk@... [DynoMotion] <DynoMotion@yahoogroups.com> wrote:
Hi SJH,
Yes, but I couldn't work out how to do that from KMotionCNC user defined buttons and M codes - unless you can enter a .out file instead of .c (I didn't try that).
OK, that gives me more motivation to do a good job.
SJH
Group: DynoMotion Message: 12232 From: Tom Kerekes Date: 9/8/2015
Hi SJH,
Oh.  Here is a patch that should allow GCode Interpreter Actions with .out extensions to be loaded only.  Also the changed source files:
Will also be in the next Version.
